View Single Post
Old 06-18-2023, 01:24 AM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Could be an injector as they are a common problem after a few decades, and possibly wiring, or missing teeth on the crank sensor trigger ring, not sure if a bad cam sensor would cause this?
Malcolm99 is offline   Reply With QuoteReply With Quote
