Originally Posted by JohnMc
My fridge (Dometic) has 3 different battery protection settings, and if you're running it off your only battery, I'd have it on 'high', probably be OK overnight.
I have a dual battery setup in mine, though, tiny Braille start/car battery, and a yellowtop 'house' battery. The yellowtop is a combo deep cycle/start battery, advertised as 48 aH capacity. Running on 'low' protection, mine would run the Dometic for a couple of days before the Dometic would shut off to prevent totally draining and damaging the battery.
Show me you setup please.
My Chinese knockoff 75l dual camera fridge also has 3 protection settings. Shuts down with protection almost immediately when car is not running, while running barely works🤦, and if I put it in emergency override mode while engine is running works fine for a few minutes and than shuts down with low battery warning.
Tested the battery with battery tester and it shows as week battery, so I bet is is time for replacement.
I think I better do dual battery set up, but don't have time and long weekend is coming up.
