Originally Posted by brillo_76
Getting thin.. I would remove the control arm. Weld up the outside of the bracket with a thick washer and some metal ground it smooth and good for another 5 years. I have had the uppers rust off. The lowers on thr frame just loose and the upper on the pipe rust off.
All fixable.. lol. Rust belt hard on things.
You may have some business if you can replicate all the body mounts and frame brackets that are disappearing from Toyota inventory.
Fabricator here; he's in West Virginia otherwise I'd gladly cut off and weld the new ones. We're making it a pair now.
Even though the bracket is 1/8" like the frame, I'll be cutting it out of 10 gauge.
Long as it's rust proofed afterward it should hold up fine.
Got his final dimensions and I'll be cutting up parts tomorrow. Will post here once I do so.
