Real Name: Mark
Real Name: Mark
When did you notice the wet ABS ring? As you were pulling axle from tube the first time for this job?
If so, seals are seeping. Tone ring is free and clear of axle housing before lube has chance to get it wet.
Did you pull axles all the way out an store them standing upright on studs while installing locker?
Now that would give you lube on the tone ring.
I've pulled axles on a full diff you can pull it, turn, stand on studs out of the way, be back in time to stuff
a rag in tube with little loss.
