Originally Posted by Oneluv13T4R
Your in lockdown mode..Complete LOCKDOWN
Just had the same thing happen to my 03' 4runner SR5. Two days of completely freaking out til ...I read so much that i started reading between the lines of the repair manuel.
What you need is 2 keys
1 key goes in the ignition and turn it to "ON"
2nd key goes in the rear hatch door using it to work all the functions of the rear door. Do the typical turn and hold down turn hold up etc etc.
Why 2 keys? cause its a safety mechanism as if a child was stuck in the door it will n oit come out of that mode until two keys are used assuming two people are verifying everything is ok..and walah
You just saved me a trip to the dealer. 3 years ago I installed a radio in the wife's 08 and the window, defrost and wiper stopped working. I have looked through so many posts on and off for the past 3 years and you are the first I see with the 2 key method. Wiper and defrost now work, window now works from the hatch key hole and only down works from the remote. Dash button doesn't work either, but the wife is super happy. Thanks! I'll figure out the other things later.
