2007 Honda Accord 3.0L V6
Maintenance & Build Log:
9/1/23 - Radiator replaced/tensioner replaced, OEM Honda blue coolant added, N/A mileage
9/8/23 - Lower control arms replaced, oil change, SuperTech Full Synthetic 5W-20, 15400-PLM-A02 filter, 132,309 miles
11/4/23 - I took possession of the Accord
11/7/23 - Strongarm 4157 hood struts
11/7/23 - STP cabin air filter replaced, 132,736 miles
11/14/23 - Coolant overflow reservoir cap replacement, 132,860 miles
2/3/24 - Alternator replaced with Denso p/n 210-0606, 134,497 miles
3/30/24 - Oil change, SuperTech Full Synthetic 5W-20, 15400-RTA-003 filter (Japan), 136,012 miles
3/30/24 - Transmission fluid flush (3x), Honda genuine ATF, 136,012 miles
3/30/24 - Brake fluid bleed, Valvoline Synthetic DOT 3/4 fluid, 136,012 miles
5/9/24 - Front & rear brake pads and rotors replaced, Akebono pads/Wagner rotors, 137,163 miles
5/12/24 - Spark plug replacement, NGK Iridiums p/n IZFR6K11, 137,232 miles
5/18/24 - Purge valve replacement w/ OEM p/n 36162-RJA-A01, 137,339 miles
