I tried different fan speeds but the blower didn't run. I checked the white-blue wire and there's no current. But the relay on the evaporator box clicks. I'm now starting to think that it's a wiring issue, not a worn old part.
Thank you.
Originally Posted by phattyduck
Did you try all fan speed settings? If it only works on high, or a sub-set of the speeds, it is the blower resistor.
Did you check for 12V at the blower motor while the fan is supposed to be on?
