Originally Posted by phattyduck
3rd with the torque converter locked is only a few hundred RPM higher than 4th unlocked - it won't be much different in sound. Obviously on the flats and mild hills, leave OD on...
Under load, a little more RPM is almost always a good thing - the water pump and fans spin faster (more cooling), the engine torque requirement is lower (hp = RPM x torque) which is better for engine, and it is better for transmission heat (no or less torque converter losses). 3rd locked will be *better* for mileage than OD unlocked - along with being better for the rest of the drivetrain.
For the same set of reasons, 4LO is better when going slow offroad.
Oh dang, sounds like OD off is pretty much good for everything when traveling a consistent incline. Any idea if ECT does any good or harm in that situation? Since I re-geared to 4.88, I've been thinking of leaving it on all the time since it feels a little better when accelerating from a stopped position (it feels like it jumps into 2nd gear a little too quickly and ECT seems to help a bit with that).
BTW, thank you again for all you super-informative answers! Without helpful people like you and the other posters on this forum, I'd probably be dealing with a busted transmission in the near future.
