I'd start with basics like ensuring batt connections are tight, might even charge battery up some more, I like 12.7 as a minimum. Check ignition fuses in engine bay.
When the starter contacts wear down too much, there is still a click caused by the plunger trying to hit the contact. The fact you hear no click might mean no power is getting there, so check up stream to battery.
Let us know what you find.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
