Originally Posted by mtbtim
It wouldn't be a bad idea to replace the fuel pump and filter inside the tank. They have been known to fail which can leave you stranded. The hardest part is making all the disconnects to drop the tank. Once the tank is out, removing the fuel sending unit assembly is easy. Replacing the fuel pump and filter on the fuel sending unit assembly is also easy and straightforward.
You can use my video to learn how to do most of it. We don't show replacing the fuel pump, but it is very easy once you have the sending unit in your hands.
You should definitely replace the rubber gasket that seals the sending unit to the top of the tank. We have it linked in the video description.
Your video is literally bookmarked on my iPad for when I start the repair lol. Thanks for your channel and advice!
