It may be a bad pump, although they typically work or they don't. They fact that it squeals at full lock tells me the belt may be a little loose or worn out. Toyotas need their belts TIGHT. The PS belts on a lot of older Toyotas also don't squeal when they aren't tight enough for some unknown reason.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
