Originally Posted by Toy4wd
I have a 2008 Limited 2WD and had the exact same issue. I replaced my gas cap with OEM and that fixed it permanently. If you scan tool, you see codes related to EVAP.
Originally Posted by zguy1
Not sure if you’re on the right thread here, info for codes was already noted and the gas cap has already been replaced.
When the gas cap seal is bad you will also have the "Check Engine" light on as well.
Since the Check Engine light is not mentioned being on then it can't the gas cap.
