Real Name: Tim
Real Name: Tim
2UZ-FE Starter Replacement
Hey Dudes,
If you have the 4.7L V8 2UZ-FE engine and are faced with a starter failure or you're planning on replacing it as preventative maintenance to avoid getting stuck out in BFE, this video will show you how to replace it. The starter replacement isn't that bad for owners that don't have the secondary air injection system. The 2UZ-FE 4.7L V8 Engine got an update in 2005 with VVT (Variable Valve Timing). With VVT, the engine unfortunately also got the secondary air injection system. The secondary air injection system makes the starter replacement much harder to pull off. This video will work for anyone with the 2UZ-FE engine wanting to replace their starter, but it will really benefit those with 2005 and newer rigs.
This is Part 1. Part 2 will be coming out soon.
Hope you Dudes enjoy it. Happy Wrenching and Sic Mods for All!
