View Single Post
Old 10-27-2023, 09:58 AM
luckyluke luckyluke is offline
Real Name: Lucas
luckyluke is on a distinguished road
Real Name: Lucas
Replacing brake fluid proper way
Hi,
I am going to just replace the brake fluid in the system.
Is the procedure from the Haynes manual for bleeding brake system the right way to do it?
I.e:
- (Front), ignition ON, wait for the pump motor to stop, pump pedal several times, depress pedal, bleed
- (Rear), ignition ON, depress pedal, bleed
- engine OFF, pump pedal 40 times to remove boost pressure
- done
I did it a few years ago when servicing calipers. Now I just want to replace the fluid. No air was entered in the system.
How much DOT3 will be sufficient?
2007 SR5 4x4 V6. Bilsteins 5100 all around. Front set to 1.75. Daystar spacers 1.5 in the rear. Stock springs. Cooper Discoverers A/T3 265/75R16.
luckyluke is offline   Reply With QuoteReply With Quote
