Originally Posted by Bad Luck
I put a light coat around the outside of the inner axle seal. Double check you are in the correct spot on the retainer with a sharpie test. With that much gear oil making it past the seal and through your axle bearing you will probably have to replace the axle bearing sooner than later. The gear oil leak washes out the axle bearing grease.
The last time I pressed the inner ring in about 4.5mm and that put the seal in the center of the ring. From what I remember, the sweet spot seemed to be 4.5-5mm for people.
I bought a Koyo bearing and ring set from napa which is what I used last time. I'll keep the bearing I pull out because I might be able to flush it and repack it for next time. I also bought Toyota snap rings, dust seal and inner seal. I'll seal it up good with the FIPG sealant. When I'm confident it's no longer leaking I'll replace the brakes. I bought Napa shoes and wheel cylinders but I don't want to do all of that until I have the gear oil leak fixed.
