Originally Posted by werminghausen
I was looking at the removed and obviously failing motor/pump accumulator unit on my bench.
I could easily run the el motor and fluid was squirting out at the pump outlet.
The pump could be a 3 cylinder piston pump but not 100% sure.
My theory so far: the pump was failing and could not deliver the required pressue. This lead to the dashlight not clearing.
Well I still have no proof but I might take the pump apart at some point.
Here is a picture of the motor inside... it looked pristine, like new, see picture.
Martin
yeah, the motor is in great shape, you can sell it for a couple of bucks on ebay. wish i could get my hands on the motor, my 2nd replacement unit is failing again and its either the motor or piston assy
the 2nd likely culprit is the oring on the piston assy. its a 60 dollar part.
the accumulator rarely goes bad, its just a metal cylinder and an o ring on top. its easy to see/know if the accumulator is leaking, as slight fluid would be seen leaking from the top/connection
anyway great news your brakes are working ok now
2005 v6, galactic grey 4wd auto :
pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......
sold
2004 rav4 titanuim silver 4wd auto :
pionneer avhx 5500bt hu, pyle reverse cam
