Real Name: brian
Real Name: brian
Fuel trim question
Hi all. I've been chasing down a poor running '08 v8. This thing was a mess when I got it ( dealer screwed me, sight unseen ). Anyway its got 127k on it. This is what has been done by me, basically maintenance stuff:
Full tune up with oem parts
All vacuum lines replaced with OEM lines
Timing belt and pump done
Cleaned MAF and TB
rear cats deleted with URD y pipe
All 4 O2 sensors are original not replaced.
Here's my problem. It uses alot of gas compared to my '06 v8 and has a vibration at idle and higher RPM's. Put my scanner on it, short fuel trims both sides hover between -.07 - 1.5. Long term stays steady b1s1 -1.3, b2s1 +9.3. Those are too far apart. No vacuum leaks(tested with smoke machine). Voltages are within .2 of each other. I'm kinda leaning to a bad bank 2 O2 sensor. If so I would replace both. I just had the left exhaust manifold gasket replaced, and there is a very tiny crack in the manifold. Could the crack be causing the lean cond on bank 2 s1 O2 sensor?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
