View Single Post
Old 11-24-2023, 08:35 PM
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Originally Posted by Jubsz View Post
I started my 08 V8 4Runner this morning and noticed the battery light was on. NBD, I turned it off and drove the other car in. When I got back home, I started the 4runner, heard a bit of whine which I presumed to be the alternator, smelled a bit of burning in that area and turned it off. It was registering 11.9-12V while running.
I shut it off and went to the Toyota dealership to pick up a reman alternator. I returned about an hour later and went to hit the unlock button on my fob with nothing happening. I turned the key, and nothing at all. Not a single light on or anything at all. Battery has been replaced within last 2 years.
At first, with the battery light and low voltage, I just assumed a simple alternator. I haven't gotten to do any formal diagnosis but the fact that everything died and had a burning smell is making me freak out a bit thinking it may be worse. I've gotta find my multimeter and see if the battery has anything in it. Shouldn't I still be seeing some dash lights? It's odd that the battery had enough to start and turn off, then nothing an hour later with the burning smell.
Anyone had similar and what else was it? Alternator job was looking like a pain on the daily but I was going to do it. If it's significant electrical, I'm afraid I may have to get it towed somewhere.
I am hoping it is a stuck pulley! It would make sense that your battery would be completely dead as that first run cycle would've been 100% powered by the battery itself. The main reason I think alternator is because our charging ranges from 13.1v-14.2v a bit higher than what readings you acquired.
If it is totally dead, no dash lights would power on and your door locks wouldn't function. On my last 4Runner, I had a whopping 4v in my battery due to a similar situation and I couldn't cycle my locks or even get the dash lights on for less than a second.
I wish I could smell what the burning smell actually smelled like as a belt burning is different from an overheated electrical component smell! But alas, this is what a fuse block is for! It should contain the electrical issue to the engine bay side if there is an issue there and protect the components inside the vehicle. It may be of benefit anyway to replace the 140 fuse and belt as maintenance items any-who regardless of its possible problem solution.
I hope you can get it figured out!!!
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
