Originally Posted by Iffykid
Has anyone installed a winch in a 4X front bumper?
4X claims a winch will fit in the front bumper with clocking which it will the problem is the control box will not.
Two options I see at this point are.
1. Remote mount the control box under the hood somewhere and add 3 longer cable leads $$$
2. Cut a area out of the top of the bumper and also remove a section out of the bottom of the grill just below the Toyota emblem so that the control box could be mounted in a normal fashion.
IffyKid, what did you end up doing? If you were successful, what winch did you end up going with?
