Real Name: Ron
Real Name: Ron
Not sure how you spend $5K upgrading the suspension unless you're putting Kings all around. You should be able to that work for less than a 3rd of that amount I would think. Don't farm out the easy stuff.
If UCA and LCA needed too, then probably $2K for suspension if you do yourself.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
