Originally Posted by Humble Leader
easiest way is to remove one bolt without touching the other. then put the bracket in and the bolt back. tighten it tight enough that you can just pivot the bracket with applying some force, start where you can't move the bracket then loosen slowly until you can. then remove the other bolt and pivot the bracket to line up the holes. tighten everything up
Thanks. Somewhere I had read a snippet that implied that technique but your details explain it clearly. I'm going to add some more coats of paint to my brackets and install them tomorrow when the lights arrive. I think I've settled upon where I will install the sPod box under the hood and have to work out some brackets.
Jim _ My Adventure Blog:
http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
