Originally Posted by comtn4x4
I have been running just the passenger side arm consistently since early spring. I went back and forth only passenger and both a couple times to see if I could tell a difference and there's no notable difference I could identify. As
@ honda250xtitan
suggested going with the passenger side only seems to be a good way to go. That being said I am running a significantly upgraded UCA with Heim joint, not sure how that would compare to the OEM UCA.
thats good to hear. I wouldnt run OEM arms with just 3 of the links.
