Originally Posted by 4genrunner
She also has/had an aftermarket remote start installed.
can you remove the remote start or at least unplug power to it? this is the issue with remote starts. even if they are installed properly by a real pro they can still cause problems later. this is my guess. my vehicle came with a remote start and I removed that right away. they spliced right into the wires and when removing the unit and sealing up all the splices I found one factory wire completely severed in half, being held together by the splice........ good thing I had the tools and equipment to fix it properly or my rig would have been effed half in my garage...
Originally Posted by To_fire
My guess: The Neutral Safety Switch is telling the engine control module that you're not in Park so it won't let you start the engine.
OP did you notice the shifter being difficult when trying to cycle the gears recently?
