Real Name: Todd
Real Name: Todd
Water pump and timing belt are generally done at the same time. Why are you only replacing the water pump?
The water pump needs to come off before you get to the timing belt either way, so those videos should help.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
