Originally Posted by SurgicalApple
Recently purchased a set of new wheels and kept the old tires (only a few months) on them. After the work was done, I noticed a vibration in the steering wheel when approaching 45-50mph and when actively accelerating at that speed at that speed as well. Previously, this was never an issue. Took it back to to Discount Tire where they did an alignment, rotation, balancing, and adding those weight clips to the wheels. Unfortunately, I am still feeling the vibration. What gives? What should I ask to be done to remedy the issue?
Toyota truck steering racks from this generation of vehicles are very sensitive to wheel balance.
You need to have your wheels/tires Roadforce balanced. Roadforce machines will give you a number that tells you how out of round the tire is. For SUVs and trucks, under 10 is great, 10-20 is acceptable, 20+ is bad. When you get the tires balanced, ask for the Roadforce numbers for each tire. Then have the highest numbers put on the rear. This will clear up most of your vibration.
You will probably still get some vibration when the vehicle has been sitting for a while, especially when it is cold, as the tires tend to get a flat spot where they have been sitting. This vibration usually goes away once the tire is warmed up.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
