Going to use this post as my maintenance log.
1/8/24
215,473 Miles
OEM AC Condenser -
Land Cruiser Specialists
1/13/24
215,473
OEM B2 S1 O2 Sensor -
(8946560150) Tom Wood Toyota
OEM Coil Pack -
(90919-02230) Tom Wood Toyota
1/30/24
215,473
Detroit Pass front Wheel Bearing -
Amazon
Denso Coil Packs -
(6731303) Rock Auto x7
2/7/24
215,495
OEM Radiator Shroud -
(16711-50170) Joe Joe Toyota Parts
OEM Fan Clutch -
(1621050090) Tom Wood Toyota
OEM Fuel Tube Clamp -
(7785-35630) Joe Joe Toyota Parts
(7785-35640) Joe Joe Toyota Parts
2/12/24
215,501
New Spare tire changing tools
Amazon
3/2/24
215,511
Cleaned Sun Roof Drains
OEM Relay Block Cover -
(82663-35090) Toyota Parts Deal
OEM B1 S1 O2 Sensor -
OEM PCV Valve -
(12204-50030) Toyota Parts Deal
OEM Gas Cap -
(77300-47010) Toyota Parts Deal
OEM PCV Hose -
(12261-50060) Toyota Parts Deal
OEM PCV Hose -
(12261-50050) Toyota Parts Deal
3/11/24
215,520
OEM Feul Resistor -
(23080-50130) Toyota Parts Deal
OEM MAF Sensor -
(22204-75020) Toyota Parts Deal
OEM Vapor Hose -
(23829-50070) Toyota Parts Deal
OEM Vapor Hose -
(23820-50140) Toyota Parts Deal
OEM Thermistor -
(88790-22131) Toyota Parts Deal
Battery
Duralast Gold 27F-DLG - AutoZone
3/21/24
215,532
Bearden Automotive. They use OE parts and for this they used the ASIN kit.
B2 S1 O2 Sensor Ground fix
Timing Belt Idler
Cam Seal x2
Crank Seal
Timing belt
Water Pump
Idler lower Timing
Coolant
FIPG Sealer
Thermostat Gasket
O-Ring Bypass
Inlet O-ring
Thermostat
Tension Adjuster Timing
P/S Hose 3/8
P/S Feed Hose
Power Steering Fluid
Oil Pickup Gasket
Oil Pumo/RM Housing O-Ring
Oil Pump
Tensioner Accessory Belt
Harmonic balancer
Alternator
Cooling Bracket Assembly
4/8/24
215,674
Lubed front & rear driveshafts (slips & u-joints)
5/13/24
215,690
Krawltex Motorsports
Installed
SafeTcap Frame Repairs 200,201 & 202 on both sides
5/22/24
215706
Bearden Automotive.
New Radiator & Cap
