Originally Posted by Jeremy556
The cheapest model (88 I think) is pretty crappy, but all of their main stream models are the gold standard of 12v compressors.
I've been running dual 400s in an OBA setup for over 10 years and use them several times a week to fill 35x12.5x17 tires from 3-8psi up to 35, as well as run an air locker. Only failure I have had is rubber leader hoses that dry rotted after 8 years. Easily swapped those out for a few bucks and 5 minutes.
Another nice thing about Viair, is you can buy replacement parts, not that you'll likely need any for a long time.
Viair compressors a good, I am not sure how they hold up to the elements if left outside though? I use a 444c but its in the trunk of my g35 for the air suspension.
