View Single Post
Old 01-05-2024, 05:42 PM
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Bus bars sound like what you want. if those aren't enough, a 34/78 group battery should help (double terminal). I have some epoxied to the top of my 34/78 battery to make things cleaner. However, this -
Originally Posted by phattyduck View Post
I got new OEM replacement terminals meant for an Avalon from around the same vintage:
90982-06022
90982-05035
Then, I made a custom buss bar to run off the positive terminal (copper bar, bend and drilled):
It has:
Headlight harness
Offroad light harness
Trailer brake and charge (on breakers)
Winch (also on breakers, but can easily be bypassed if needed)
It is wrapped with both heat shrink and silicone fusing tape for protection.
The ground side just has the engine, fender and winch connections. Charge wire, ground wires, etc are routed as OEM but all 4 gauge. Alternator is a 105 amp Denso from a Grand Vitara.
Is a very slick way of mounting it as well.
