View Single Post
Old 01-08-2024, 02:11 PM
4runnerfever67 4runnerfever67 is offline
4runnerfever67 is on a distinguished road
Originally Posted by thegipper View Post
I had a similiar clunk and it was due to me putting too much grease in the slip joint zerk on the rear driveshaft. To fix it, I removed the slip joint and cleaned out all of the excessive grease. I then just brushed on some grease onto the teeth of the joint. I also left the zerk fitting out until I found a "breather" fitting to replace the zerk fitting. Basically too much grease doesn't allow the joint to move back and forth easily which can cause binding in the drive train. This has been a problem with other people as well. Mine hasn't clunked once since I made the changes.
May not be your "clunk" but it's worth taking a look at.
I will definitely check this out today. What is the breather replacement you are talking about?
2000 4runner limited
4runnerfever67 is offline   Reply With QuoteReply With Quote
