Originally Posted by Down by the Water
There are two sensors (one front and one rear) that are installed in the lower intake plenum. I busted both of them trying to get them out to clean the plenum. Toyota does not sell the sensors separate from the plenum and a new plenum from them is about $600. I bought a used one, with sensors intact, for $65. I found out later that you can buy the sensors from Rockauto. I’m re-building my old plenum now, as a backup, I guess?
I'm not sure whom you talked to, but both those sensors are available separately from OEM.
Cluster gauge coolant temperature sensor 82219-34020
ECM coolant temperature sensor 89422-35010
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
