Originally Posted by ArthurKotb
Is the window binding on the rubber seal, the one around the sides and top? That comes out fairly easily. I removed and replaced mine with a new one in about 15 minutes, no sealer/glue, per the parts department. You might try removing it and see if that helps. At least check the rubber as you raise the window, maybe push on the edges and see if the window goes up further.
There are several things that could be the problem; motor dragging, poor ground, poor power connection, binding in the channel, etc.
I'm not sure. I tried using silicone lube last night and didn't get much change. I got maybe another inch out of it and it repeats the whole rolling back down thing. I did take the bottom seal off and had no effect, but that is just the brushes part, really.
