Originally Posted by Usurper
I'm looking into this to see if anyone has experience connecting those new lights to the OEM wires so I can use the OEM fog switch on the turn signal. As I said before, I want to use Baja Designs squadron lights.
"baja squadron to xxxx (fog light bulb size) adapter"
I forget the # offhand but you can buy a premade adapter fairly inexpensively by searching that phrase. At that point it'll plug straight in and work off your fog light switch. It's also far lower draw than the OEM fogs so no risk of overloading the circuit.
