Originally Posted by OopsIBrokeIt
"baja squadron to xxxx (fog light bulb size) adapter"
I forget the # offhand but you can buy a premade adapter fairly inexpensively by searching that phrase. At that point it'll plug straight in and work off your fog light switch. It's also far lower draw than the OEM fogs so no risk of overloading the circuit.
Plug-and-Play LED Light Adapter Harness H10/9005/9006 - Baja
These should work fine then correct? Just posting them here to confirm and for others, if anyone else finds themselves in my situation.
