Originally Posted by mrblah
i havent been following this thread as closely as i should have been, but which model/manufacture of trans cooler does this fit?
thanks a billion
A billion "You're Welcomes" lol
2010-2024 4runner Transmission Cooler Bracket Kit
– Iconic Fabrication
CURRENTLY IN THE PROTOTYPE STAGE, HOPEFULLY SHIPPING BEGINNING OF 2024!
These CNC pressbroke .125" thick 5052 aluminum brackets are designed to make transmission cooler installs a breeze for all automatic transmission 5th gen (2010-2024) 4runners! These fit the Hayden 678, Hayden 698, and Derale 13613 transmission coolers. The Hayden coolers are identical in size but the 698 is equipped with an internal temperature bypass which helps the fluid get up to operating temperature faster, recommended for colder climates. Reduce wear on the transmission by keeping temperatures cooler!
I have not test fit this bracket on every single model year of 4runner. Depending on options there may be things that need to be moved out of the way. I'm waiting to hear back from customers regarding fitment for various years. If it doesn't fit your vehicle, take some pictures of the issue and I can provide a full refund.
Included with the "Bracket Only" option:
Bracket
All required fasteners
Included with the "Hayden 678 Kit" option:
Bracket
Hayden 678 (non-bypass) cooler
Additional length of 3/8" transmission hose to complete install
Edge trim guard
(4) hose clamps
Included with the "Hayden 698 Kit" option:
Bracket
Hayden 698 (bypass) cooler
Edge trim guard
(4) hose clamps
If you purchase a kit option all you need to complete the install is a quart of your favorite automatic transmission fluid. I recommend Toyota WS ATF or Valvoline Maxlife.
Unfortunately I'm not offering a Derale specific kit at this time.
Jim _ My Adventure Blog:
http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
