Originally Posted by Dave98
Thanks for that. Fast Reply and good info.
My 98 3.4L Auto Trans 4WD has about 178K on the clock, so it’s about time for these contacts to be replaced though it seems quite a few ithers have gonemuch farther before needing them changed.
I was having the more-key-turns each day problem for 3-4 days until now it just wont start. Gonna check and clean and multimeter every wire connection and go from there. But I want to have the contacts right there when I do it.
Thanks again everyone!!
If you can get the Reman Denso from Napa, just go that route. By the time you pull the starter, and replace the contacts, you can have a totally rebuilt started with a warranty. I went though the whole starter contact replacement, but my issue was the Bearing in the bendix came apart and was causing the plunger to hang.
Good luck whatever you decide.
