Originally Posted by Bad Luck
Center of hub to fender measurement is helpful for other people because it takes tires out of the equation. Even if 2 people are running the exact same tire size but different brands the actual tire size will be different. My 265/70R17 bridgestone tires will measure differently than 265/70R17 bfg all terrains.
You are adding scenarios that are not ours. We used the same exact wheel.. not a similar one. So the measurements are still accurate. You are arguing a point we all know.
