Real Name: Blair
Real Name: Blair
Swapping a radiator is easy - hell, even I did it. The alternative would be to cap and bypass the radiator's cooling tank altogether by installing a dedicated ATF cooling system but doing that took me as long as the radiator swap if memory serves (I have both). You'll probably spend the same amount, too. In any event, the radiator is right up there with the LBJs as must-do preventative maintenance. Everything else can wait.
