Does it start if you keep cranking it? Any signs of chewed wiring or mouse nests?
Do you have access to Techstream or a good scan tool? There will be a P1604 code stored (no MIL or anything a low end scan tool can see) along with freeze frame data from the event, which has info like rpms from the crank sensor, immobilizer status, fuel pump activation, etc.
