Originally Posted by hoppyjr
Your new one will have LED low & high beams standard, along with LED fogs.
The DRL on the 22+ remains the ugly halogen, whereas the high beam is part of the projector where the low beam is.
If your fogs are real high quality aftermarket units like Baja/Diode Dynamics/Morimoto then I’d keep them and use on the 2024 as they stock ones are just ok.
You could keep your LED high beam bulbs since they are simple to remove. On my 2022 I switched off the DRL function, then removed the halogen DRL bulbs (which remain in the same position as your 2020). I installed 9005 LED bulbs and wired them to my switch panel as auxiliary high beams. They work great. (see my build thread for details).
That's correct, and i can tell you, at night when i put my high beams on to look at afar signage or when i go to a nearby trail i go do regularly .... they light up more area but with less intensity compared to the LEDs The stock leds are much brighter! And my old after market LEDs for high beams 9005s were much muchhhhhhhh brighter.... but even if i had kept those aux LEDs apparently they would not have worked, as they are not PWM + anymore..
