Real Name: Dave
Real Name: Dave
Sounds similar to what happened on my Subaru Outback. It turned out to be a front wheel bearing slowly failing. The sound only occurred at parking lot speeds, a sharp right turn. the sound occurred with each tire rotation. Later, the outboard tire would start to slide to the outside an inch or so. No other symptoms. Replaced both hub assemblies. Corrected the problem.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
