Real Name: Ron
Real Name: Ron
There is a way to measure the amount of moisture in your fluid, you might google that. Since you live in Washington, high humidity all the time, I'd get a new cap for the master cylinder and see if that helps.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
