Originally Posted by Charles Bronson
I want to run the OEM LED low/halogen high beam housings in my wife's 2020 ORP. I read a ton of the threads on this forum and some of it is confusing. I have no desire to get the OEM LED low/high beam setup as we rarely run the high beams and honestly find the halogen lighting on the high beams to be plenty strong.
I just want to make sure I understand things correctly before ordering parts. Based on my research, I need to order and complete the following to do the conversion:
LED w/ Halogen High beam
Left: part# 81070-35600
Right: part# 81140-35610
I can then unpin the low beam connectors from the old housings and install install onto the new housing and that's it to complete the conversion.
If I don't want to unpin the wires and swap connecters, I can buy the "No shutter" harness here: 4Runner 2014 - 2020 OEM bi-LED Headlight Conversion Harness | FBC Harness Solutions
Thanks for the help.
I don't know if the part numbers are correct but I did this exact install on my '19 TRD ORP. I got a set of used headlights from a '21 T4R off of ebay. I did the unpin deal as there was no harness available at that time. No problems at all and they work & look great.
In case you aren't already I'd suggest swapping out the fog lights with an OEM LED set to match. They are a direct swap as the connector is the same and will be easy to install since you'll already have the bumper off to install the headlights.
