Originally Posted by RodrickHeffley
It is a set time each time, or just a general time of a few minutes?
The wire that sends it up to the cluster, or in your case, the security system, might be breaking, which is common. It might just by chance be able to get enough of a current to trigger the alarm after a while.
Does the alarm re-arm after opening the door?
I believe it is a set time, I have just never actually timed it, but I'll admit I'm not sure.
What can I do to test if it's the security system, and are there any known fixes?
I'm not sure what you mean about the alarm re-arming after I open the door. The alarm will go off if, after unlocking the truck, I only open the rear hatch and leave it open. However, if I open any other door then the alarm will not go off.
