View Single Post
Old 02-02-2024, 02:43 PM
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Just from eyeballing it you can clearly see how out of line the control arms are. The mount brackets on the axle look bent out of position. You can also see how cockeyed the bolts are through the bushings and bracket. You shouldn't jack your truck up like that first of all. I doubt it's a serious issue. If you're mechanically inclined and have decent intelligence you can probably fix it for free pretty much. What you need is a tram tool and the point to point data to verify the frame is straight and locate where the problem lies. It might be hard to find the point to point data because typically that information is hoarded by body shops and costs money. You can find it though if you try hard enough, I've had to find it before. I'm putting my money on one or more mounting brackets bent out of position. You can probably fix it with a hammer or some kind of pry tool and muscle. I would also go ahead and get new control arms or refurbish the bushings. They've most likely been damaged. Hopefully it's nothing major.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
