View Single Post
Old 02-03-2024, 12:48 PM
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Originally Posted by trashboy View Post
thanks for the replies guys, i ordered some 99+ headlights and was about to order the rest of the supplies needed, but am a little confused on how everything gets wired up.
would something like this kit be sufficient?
https://www.morimotohid.com/morimoto...tem?quantity=1
35w ballasts
9006 4000k bulbs
9005/9006/9012/h10 wire harness
is the antiflicker capacitor nessecary?
for context, i am planning on ordering the square mini d2s projectors from morimoto with a panasquare shroud.
https://www.morimotohid.com/morimoto...ors?quantity=1
Interesting, TRS is undercutting their own dealers (they've been told to do MAP pricing for a few years now) with that discounted price on the square 5.0's
Wrong bulb and wire harness selection. No antiflicker capacitor needed.
If yours is equipped with DRLs, bypass them, there are a few how-tos on this forum, and run a Motocontrol harness https://www.morimotohid.com/morimoto...ess?quantity=1 But if you're not scared of doing your own wiring a basic relay harness with 9006 connections and some diodes and H4 plugs will do the job.
Non-DRL, you can also run a basic harness minus the diodes.
It's cheaper running NHK G3 ballasts, and a much lower failure rate than those Morimoto ballasts AMP: NHK G3 38W Ballasts – Lightwerkz Global Inc I suggest getting Philips or Osram D2S bulbs and the premium AMP-to-D2S adapters from Lightwerkz also
