View Single Post
Old 02-04-2024, 07:20 PM
ninethings ninethings is offline
Real Name: Tim
ninethings will become famous soon enough
Real Name: Tim
Originally Posted by 3ToyGuy View Post
Did you consider the Fuel Pressure Regulator?
Increasing the fuel pressure in the rails is what it's there for. When the engine, and thus the fuel rails, gets good and hot, there can be a great deal of bubbles forming in the liquid, causing lack of functionality in the injectors. The pressure regulator will increase the pressure the rails are under, decreasing the amount of bubbles that can form in the liquid. Once it cools down, the fuel rails will no longer need the higher pressure, and the fuel pressure regulator will decrease the pressure to the normal function pressure.
All this is controlled by the temperature sensor, I believe that also feeds the ECU, which then activates a VSV, applying vacuum to the pressure regulator, increasing the pressure. The pressure regulator is operated by a diaphragm, which is known to tear, thus no longer functioning. Less common a problem, but still a possibility, is the vacuum line feeding the FPR leaking, and/or the VSV ceasing to function.
Just a few thoughts I got. I get so few any more...
Pat☺
Would excessive pressure in the rails cause the starter to behave that way? I’d get that if it had a hard time cranking but what I’m experiencing it doesn’t even get the chance to crank. Not a *thunk* like the starter tried to cycle the engine, just a flat *CLICK* from the starter. I’m going to have the battery tested again this week. It’s still under warranty might just see if I can get it replaced. I’ll check the FPR and VSV this evening. I know my charcoal canister is going bad so that could be an off chance culprit. Thanks for the input 🤙🏼
<a href=https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEhRUBHdN4dX3N-MZqnf4MmbxaF1QVQ8kLoGcbvEX3SNwSyV_geqoX9F5LACC8BWf7UQIBzi5AC5qHBgksRfky-s3P1k9Pp-70LTMpPzK__f2bK2f30sbQq_zRuN3Cqwx93feDQ9Ndb2dQav6nodFdYVRSNBnDFeeSfFIiVfUq0VyQ3yYr93Gg0IjfTdAO0/s320/IMG_4239.jpeg target=_blank>https://blogger.googleusercontent.co.../IMG_4239.jpeg</a>
ninethings is offline   Reply With QuoteReply With Quote
