View Single Post
Old 02-04-2024, 09:45 PM
velogeek velogeek is offline
velogeek is on a distinguished road
Baja Designs lenses are user-serviceable so you can remove those 4 face screws and inspect the seal and lens. I had a moisture issue with an S1 light and found the seal was slightly pinched at the factory. They sent a replacement out and I was good to go.
When you reinstall, not a bad idea to wipe the seal down with some dielectric grease. Don't lay it on thick, you just need a little on your fingers and run the seal between them. It helps it seat in the channel a bit easier so you don't pinch it.
velogeek is offline   Reply With QuoteReply With Quote
