View Single Post
Old 02-04-2024, 10:13 PM
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Originally Posted by airbur View Post
I searched but couldn't find this exact issue. 2003 V8 Sport....when the ignition key is turned from ON to ACC (door remains closed) all the doors unlock. I've reviewed the instructions in the manual multiple times and this isn't even a function it mentions...let alone how to program/cancel it. Has nothing to do with the gear lever position etc. I'd like the doors to remain locked when the key is moved from ON to ACC. Any suggestions?
Thanks!
I'd suggest checking if there's any aftermarket alarm or keyless entry system installed. Sometimes these systems have their own quirky behaviors.
If that's not the case, it might be worth taking a peek under the hood (figuratively speaking) – check the wiring around the ignition switch and the door lock system. A loose connection or a worn-out wire could be causing this mystery unlock.
weberlukas74 is offline   Reply With QuoteReply With Quote
