View Single Post
Old 02-05-2024, 02:40 AM
slonny slonny is offline
slonny is on a distinguished road
Originally Posted by Jeremy556 View Post
Does it start if you keep cranking it? Any signs of chewed wiring or mouse nests?
Do you have access to Techstream or a good scan tool? There will be a P1604 code stored (no MIL or anything a low end scan tool can see) along with freeze frame data from the event, which has info like rpms from the crank sensor, immobilizer status, fuel pump activation, etc.
I wish I saw this reply a little earlier.
P1604 code was indeed stored. I didn't know about the freeze frame data from the event. If I only knew about this I could have narrowed down the problem to what it really was.
I don't have a scan tool, but I use OBD android apps for diagnostic purposes. The 3 that I use are Car Scanner, Torque Pro, and OBD Fusion. These were enough to do diagnostics for Engine Coolant Temperature Sensor, Crankshaft Position Sensor, MAF Sensor. For fuel pump I used DIY fuel pressure gauge.
Is it possible to read freeze frame data from the event on OBD android apps, or I need an actual scan tool for this?
At this point, I really want to invest in a good diagnostic tool that will prevent this sort of headache in the future.
Making long story short, I found what the problem was. It was the immobilizer chip in the key. If I had freeze frame data from the event with immobilizer status, I would have narrowed down the problem in a few minutes!
I found out about it in a very dramatic way when I was on the edge of mental breakdown trying to start the car that again would not start. I forcefully turned the key in the ignition and the plastic part broke off from the metal key. When I got another key and inserted it into the ignition switch it worked fine.
I returned home and removed and glued the key back in place. The car would not start with the old key, producing the same symptoms as before. It would start with a new key without problems though. I went ahead and cut out RFID chip from the old key and taped it to next to the ignition switch. With it in place I tried to start the car with the old key, and it worked fine. With RFID chip in the casing, the key would not work. Interesting...
I spent two weeks trying to diagnose the cause of intermittent crank and no start issue, looked at every system in the car, changed a bunch of parts, and never even considered that the problem could be as simple as this.
The funny thing is that if I didn't get mad and broke the casing off of the key, I would have never figured out what the problem was.
slonny is offline   Reply With QuoteReply With Quote
