Originally Posted by 2TH4IST
Probably will sag quite a bit. Back when I did my rear bumper (eimkeith's) it's 115 pounds, sagged it. Then did the f150 tank mod and it was on the bump stops lol. Running ome 891's w/lc shocks now and it rides good. The springs just settled a bit to much for me.
Are you using the OEM coil isolators? If not, you should put those in along with some OME 10mm Trim Packers to re-gain some lost lift. Those 2 items should add about 1/2" of lift.
Or, you could also try this:
W73420 Whiteline Spring - pad bushing
– Whiteline USA - 20mm Spring Pad This is designed for the front of the LC80 series springs and works with the rear of the 3rd Gen 4Runners.
W73404 Whiteline Spring - pad bushing
– Whiteline USA - 30mm Spring Pad
Hope this helps.
